Question.
Is it better for the seam to run verticle or horizontal?
Rob
mikeschn wrote:I made my seam vertical. It's backed up with a 1x3 piece of wood, and screwed in on both sides. I plan on filling the joint with Epoxy putty and sanding it flush. I think it'll be both strong and invisible!![]()
Miriam C. wrote:mikeschn wrote:I made my seam vertical. It's backed up with a 1x3 piece of wood, and screwed in on both sides. I plan on filling the joint with Epoxy putty and sanding it flush. I think it'll be both strong and invisible!![]()
Mike are you painting or staining?
Could I talk you into doing that soon so I can copy.
Miriam
mikeschn wrote:Miriam C. wrote:mikeschn wrote:I made my seam vertical. It's backed up with a 1x3 piece of wood, and screwed in on both sides. I plan on filling the joint with Epoxy putty and sanding it flush. I think it'll be both strong and invisible!![]()
Miriam
I am painting for sure... I'm gonna try to make it look like a Coleman tent...
I did some sanding and some more puttying tonight.
I think after I sand tomorrow, it'll be ready for paint.
Yes, I am taking pictures...
Users browsing this forum: Google [Bot] and 1 guest
