Woodie roof builders questions
Postby doug hodder » Thu Aug 10, 2006 10:12 am
Coldbeer...I build "tin roof" woodies...but for the screws you mention on your roof....I'd use epoxy under the skin on the stringers and screw it down...after the glue cures...back out the screws and drill it out with a forstner bit and install a bung plug in the hole...I've done a couple of wooden boats using that technique...sand the plug flush...for a sealant under the aluminum molding...3M has a product called 5200 sealant...made for below water line sealing on boats...works really well, but not cheap...Doug
Postby Miriam C. » Thu Aug 10, 2006 10:42 am
Rick,
Are you using stringer across the roof? If you are having to piece the roof it would be easier. Other wise, you need to join the pieces before putting the roof up and use one of the joinery methods.
I haven't decided what kind of glue yet so I will leave that to those who know.
Good luck
Aunti M
Postby TRAIL-OF-TEARS » Thu Aug 10, 2006 11:03 am
Rick,
Titebond III is a great glue and it is water proof too. I sealed the end of my ply with glue first then spar varnish.
Steve J.
Home built Camp-Inn clone.
GO SPURS GO
TRAIL-OF-TEARS
Images: 41
Postby Ira » Sat Aug 12, 2006 8:38 am
I used 3m's 5200. It's white goop than comes in a tube, it can be a litle messy to work with, but it's a sealant that never dries 100%, so it never cracks.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby Steve_Cox » Sat Aug 12, 2006 8:52 am
Rick,
I used 1/4" oak plywood for my roof. I used NO nails, screws, or staples to attach it, therefor it had no holes to fill. I used thickened epoxy as an adhesive and seam filler for the edges. The joints are stronger than the plywood itself. In other words the plywood would break apart before the epoxy joints would break. I also didn't leave the side wall and top edge plain, I laminated strips of oak together to trim the edges. Sorry I didn't answer any of the Q's, well maybe #1 sort of...:lol:
Steve_Cox
Images: 196
Postby doug hodder » Sun Aug 13, 2006 6:37 am
Rick....do you have it on tape? How are you getting Red Green? I haven't seen it run on any channels in years...PS didja ever see him give tips on how to load a boat on a trailer? Have fun on your build...I think most everyone will admit that when it is all over and done, it was worth it...Doug
wood from wherever...
Postby jay » Sun Aug 13, 2006 4:34 pm
most lumberyards deliver, although the last delivery i had included a $5.00 fuel surcharge. still, a small price to pay...
jay
Postby Steve_Cox » Sun Aug 13, 2006 6:23 pm
doug hodder wrote:Rick....do you have it on tape? How are you getting Red Green? I haven't seen it run on any channels in years...PS didja ever see him give tips on how to load a boat on a trailer? Have fun on your build...I think most everyone will admit that when it is all over and done, it was worth it...Doug
The Comedy Network
The Red Green Show
Weekdays 7:30am & 1:30pm ET/PT
Doug, howz that?
Steve_Cox
Images: 196
Postby doug hodder » Sun Aug 13, 2006 6:29 pm
thanks Steve....I'll make sure to plug in a tape....don't have TiVo...Doug
