Looking for door latch ideas
Re: Looking for door latch ideas
Postby Kevin A » Tue Aug 22, 2006 9:42 am
coldbeer wrote:I'm looking for side door latch/handle ideas. I want something that only involves the use of a drill to insall (i.e. I don't want to have to make square openings - so conventional trailer door latches are out.)
Its hard to see what people are using in the photos. I've seen some using house door latches and handles - but how do you seal the outside from water intrusion?
I've seen some using garage door handles but how to open/unlock from the inside?
What other types of latches/handles have you used?
If you have close-up photos, please post! :)
Thanks!
--Rick
Go here, http://www.teardrops.net/LilBear/parts.html
scroll down and you'll find what you're looking for :thumbsup:
Kevin A
The other guy
Images: 289
Postby doug hodder » Tue Aug 22, 2006 9:45 am
Rick...take a look at the handles that Grant has on his site or RW Johnson, or any of the other teardrop sites that sell parts...all install with only a drill...but there are right and lefts...you get a handle and a latch set...the latch set has a lock on it and a handle for the interior...probably your best bet as they are keyed alike and intended for this use...Doug
Postby Dale M. » Tue Aug 22, 2006 10:29 am
Here is a site that may give you some ideas.....
http://www.austinhardware.com/store.asp ... L63C500439
Check items like "Handles" and "Locks & Latches" (Cab Locks).
Dale
Dale M.
Images: 18
Postby Endo » Tue Aug 22, 2006 2:14 pm
I used the handles from Austin Hardware. You can get them keyed alike.
Here are some photos:
Outside handle/latch
Inside latch
Latch catch plate: I made this out of 2 inch wide aluminum.
You just need a drill to install.
Brad (aka Endo)
ImageImage Image
In God We Trust
Endo
Images: 138
Postby Hardin Valley Magic » Tue Aug 22, 2006 8:55 pm
Rick, what I used was cost effective and work very well. I used matching screen door handles. They are lockable and has 3 holes to bore and add a little silicon behind the plates and there you go!! Here is an inside view. There is a knob on the outside.
aka Steven D.
Hardin Valley Magic
Postby Sonetpro » Tue Aug 22, 2006 9:25 pm
I got mine from Ausin Hardware too. Like Endo said. All keyed alike.
Sonetpro
Images: 107
Postby madjack » Tue Aug 22, 2006 10:07 pm
hey Steve, have you gotta pic of the strike plate on the hatch..................... 8)
Postby Loader » Wed Aug 23, 2006 7:07 am
madjack wrote:hey Steve, have you gotta pic of the strike plate on the hatch..................... 8)
What about the inside of the door too (latch/strike plate)?
Earl & Kerry
"Loader"
Loader
Images: 245
Postby Sonetpro » Wed Aug 23, 2006 8:20 am
I'm at work now. I'll try to get some pic's tonight.
I used these. The hatch mechanism is called a slamming rod lock.
http://austinhardware.com/product.asp?d ... f%5Fid=934
Earl, I made some striker's for the doors. They look just like endo's, same inside latch also.
Sonetpro
Images: 107
Postby Loader » Wed Aug 23, 2006 8:38 am
Thanks Steve.
Earl & Kerry
"Loader"
Loader
Images: 245
Postby fornesto » Wed Aug 23, 2006 3:44 pm
I used these to hold my rear hatch down, along with a wrapping, locking hasp. Very effective. The tension from the hold downs keep the hatch tight. I used them upside down though.
fornesto
Postby hammer & tongs » Thu Aug 24, 2006 7:24 am
I used a common brass deadbolt lock as used in a house door.
Couple that with a handle inside and out and nothing more is needed.
Used 2 1/8" hole drill and a 3/4 paddle drill for the wall side.
These locks run about $5 at the depot.
Being a blacksmth, I made my own handles, but similar ones are very inexpensive.
I'm doing the same thing on my new build..
See my album..
" By whose stripes you were healed ."
(1 Peter 2:24b )
hammer & tongs
Images: 9
Postby Loader » Thu Aug 24, 2006 7:43 am
hammer & tongs wrote:I used a common brass deadbolt lock as used in a house door.
See my album..
How thick is your wall/door? This is an interesting idea.
Earl & Kerry
"Loader"
Loader
Images: 245
Postby mikeschn » Thu Aug 24, 2006 8:06 am
I used a regular lockset from Home Depot. The minimum door thickness needs to be 1 1/4".
Since I used 1/2" baltic birch for the doors, I just glued on a 1x4, which happens to be 3/4" thick, for a total of 1 1/4. But be aware, when you drill your 1" hole into the end of the door for the lockset, you'd better drill it perpendicular to the face, or it'll breakout.
We bought 3 locksets, all keyed alike... they were about $30 each.
Postby fornesto » Thu Aug 24, 2006 10:13 am
Has anyone seen the door handles that you rotate to close. It's a real simple mechanism - no latches, strike plates, etc. The inside door handle spins with the outside handle - though they are usually offset about 90 degrees. When you turn the outside, it pulls the inside radially across the inside wall until it nests, drawing the door in as it turns. Does this make sense?
fornesto
