madjack wrote:Julie, a kazillio,(maybe less) have built their roofs thataway...I am not a fan of the prime and paint finish method but once again a kazillion(maybe less) have done exactly that...a flooring outlet is about the only place that will have T mold but even they may have to order and you may have to anneal it to put a bend init...if you have to order, wait and order from Grant at L'ill Bear, RW Johnson or SoCal...you will probably be happier with their product...
oklahomajewel wrote: I have planned on using 1/8" mahogany in a double layer for the roof exterior, then 3/4 + 1/2 inch foam board insulation then 1/8" interior roof skin.
Someone (not a td builder) mentioned that it didn't sound like a good idea.
Big DE wrote:MadJack what is a "anneal"
asianflava wrote:Big DE wrote:MadJack what is a "anneal"
In a nutshell, it is heating up aluminum trim with a torch to soften it for bending.
Look at this thread, there some links at the bottom that will point you to more threads.
