Anyone else do/attempt this??
ROUGH pic follows...
Larry Messaros wrote:Eric,
Something to think about. Are you going to have the cold air blowing on your head or your feet? You might find that it is a little too close. Could you not raise it up a little more? Maybe have the box underneath for storage, or battery, with the AC above.
SteveH wrote:Eric,
I like your idea!I've seen people put AC units in tears at the foot of the bed and it causes problems of how to get outside ventilation to the unit, but your location solves that problem. You could make an aluminum "box" cover for it using RV side vents to disguise the unit. Or if you are going to paint your tear, just paint the unit box the same color.
I do think, however as Larry said, you need to raise it up a bit to keep it from blowing directly on your head.
tdthinker wrote:If you take some time on the box it should blend in nicely. I wouldnt want it blowing right at me head becuase it would go under the covers making you cold. You would have to get one with those moveable vints like in cars. bye
