Its taken a while (almost a year) but I finally have a plan that is coming together.
I have decided to build a 5’ x 11’ Modernistic TD that will be 54” tall so I can sit up on cushions and have a table.
I took the Modernistic profile drawings from the Design Library (Thanks Andrew) and scaled the locus of each of the four ellipses for the expanded profile. I set up an excel spreadsheet to give me the x-y coordinates then plotted them on a large sheet of grid paper and am satisfied with the profile.
I plan to build it with the insulated framed walls from Steve’s shop manual and wonder if anyone has had any experience with the Self Centering Dowelling Jigs from Woodcraft?
http://www.woodcraft.com/family.aspx?familyid=782
Looks like they would make stronger joints than the biscuits and not get in the way like pocket screws might when you cut the frame for the headliner.
I’m starting to buy the 1” x 4” pine for the frame so as the sublject said (borrowed from an old SCIFI show) … And so it begins.
