computer question?
computer question?
Postby catrinka » Sat Nov 27, 2004 1:57 pm
How do I put an image into my signature line? Obviously this method didn't work! :thinking:
catrinka
Images: 43
Postby Guest » Sat Nov 27, 2004 2:22 pm
Cathy,
This might work;
Go to that website and copy the image you want to use. Save it to your computer. Then go to bg's website and use his image uploader.
http://upload.nowherenews.com/
Hit the browse button and select that image from your computer, click open, then click upload. If the image is under 128KB it should upload.
If it uploads, before clicking and copying the IMG text string, change the IMG's at each end of the string to lower case letters. Then hit copy.
Now that image will be posted on a seperate page on the internet.
Now you can go back to the forum and proceed and hit paste to insert it.
Guest
Postby catrinka » Sat Nov 27, 2004 2:39 pm
Thanks Dean....it worked :twisted:
catrinka
Images: 43
Postby Guest » Sat Nov 27, 2004 2:42 pm
Hey,
I like that, makes me feel like putting up some Christmas lights, :thinking:
Or throwing snowballs at someone. :twisted:
Guest
Postby mexican tear » Sat Nov 27, 2004 3:01 pm
Thanks Dean
I am going to try that on my next pic.
:cry: I am working on the hatch, some days I think I will never get it done.
kai
"Essie" and the Mexican Tear
mexican tear
Images: 14
Postby Guest » Sat Nov 27, 2004 5:53 pm
Kai,
I wish that I was there to help.
Let me guess, about 75F, calm, warm and sunny?
It's sunny here, but real cold gusty winds.
(Not good when you have the Humboldt Crud)
Joan has me on this regiment of vitamins and herbs.
I like the herbs, but not the vitamins.
Speaking of hatches, I plan on building mine in a form, cut to the outside radius. (Like a craddle)
I've read so much about everyone fighting the hatches.
When I build mine in the craddle, I'll be able to clamp that baby up good.
My plan is to take three (maybe four) form cut-outs and put stingers in between the forms to give me clamping points.
Guest
Postby mexican tear » Sat Nov 27, 2004 6:09 pm
Dean
Heck of a good idea for building your hatch. Next time I will spend more time on the prep. This is the third one, The first two are now a roof for my neighbors three wheeler. (it is the pedal kind. They use a lot of them here)
It is just right today. We went swimming for a little exercise and to cool off. I do not miss the Humbolt Crud. We had just about the same thing when we lived in Tennessee. There were lots of oaks instead of redwoods.
Here it gets a little cold in Jan and Feb. We have to use the heat function of the heat pump a couple of times a year. ;)
I woiuld like to buy a heater for the pool, however I can not justify it for the few days that we would realy need it.
mexican tear
Images: 14
Postby Jiminsav » Tue Nov 30, 2004 9:08 pm
Kai, I found that using the gusset method of hatch construction is way easier than doing a frame and cover hatch..it goes together so well.
Jim in Savannah
Jiminsav
Images: 40
