Nitetimes wrote:Chuck Craven wrote:My homemade CNC mill is a little shaky right now.
Chuck
Like to divulge a little more info on this homemade CNC mill? That's something I'd like to hear about.
It is a flat bed beam mill.
The table is ¾” by 21” by 35” aluminum plat. The X-axis has double wide linier bearings on 1” ground hard steel rods. The Y-Axis is 1” rods also but I am using 4” oillite bearing stock. The Z-axis is made out of Delran use a dove tale bit in a router to make the ways. It worked OK when I was using a Dermal motor tool for the power head. The Dermal did not have enough horsepower to do what I wanted. So now I am using a Roto-Zip for the power head. The Z-axis is to light to handle the bigger motor so I am rebuilding it.
I am using stainless steal all threaded rod for the drive line with 200 in oz stepper motors for all thee axis. Designed my own anti-backlash nuts.
I just put together the Hobby CNC control board but have to install it on the mill. A couple of weeks ago I got my 48V 10-amp power supply running. My old controller board is home made, was designed for 120 in oz motors and can’t quite handle the higher current of the new 200 in oz stepper motors.
I use three different software packages first is a drawing package that saves the layout in HPGL file format. Then I use a freeware package for editing the HPGL file.
Third is a freeware HPGL to step and direction driver, which I rewrote for my driver board. Now days there are some nice low cost CAD/CAM software programs that can do the same job. Once my mill is running the way I want it. I will bye a program to replace the make do software I now use.
Chuck
