Ira wrote:You're not going to insulate?
I only ask because if you go with a thinner wall and frame it, I'm sure you can find the material you want for your interior walls, and get matching stuff for the ceiling too.
Ira wrote:So why don't you just get a thinner ply material for the solid wall, and laminate the interior wood that you want to use for your cabin?
Structurally, you can equal the 3/4 this way.
Solid wall requires a little more planning with the wires, since you have to run through your roof spars and under-floor, but a ton of guys have done it here.
Tripmaker wrote:Ira wrote:So why don't you just get a thinner ply material for the solid wall, and laminate the interior wood that you want to use for your cabin?
That's what I plan to do. See my earlier post.
