Steve_Cox wrote:I was thinking about putting a spoiler on my TD when I was building it to stop this very thing from creating lift on the back hatch at speed. I wonder if such a deflector closer to the top front radius of your camper would spoil the effect. It would be nice if Mike would go ahead and build a wind tunnel, we have a need to create data.
angib wrote:Paul,
My two thoughts are:
- If you are getting too much suction/airflow through the trailer, can you block off part of the vent?
- If you want to keep the current airflow, provide an inlet that doesn't give you the same problems - put a simple air filter over it, such as a piece of open cell foam and have it suck air upwards fairly slowly so that any rain drops out. It's a bit over-the-top as drawn, but a suggested arrangement is sketched below.
Andrew
