madjack wrote:Gerdo, if you are talking about regular panel type doors, you can use 1/8, since the frames will be acceptin' the hinges/latches and will control rigidity....
Chaotica wrote:madjack wrote:Gerdo, if you are talking about regular panel type doors, you can use 1/8, since the frames will be acceptin' the hinges/latches and will control rigidity....
Exactly. And don't glue the panel, let it float in the dado in the door frame.
Chaotica wrote:Exactly. And don't glue the panel, let it float in the dado in the door frame.
Gerdo wrote:My doors are just going to be a panel, no frame. These may be replaced later for a shaker style door (frame/panel)
Ken A Hood wrote:Just like the movie....... Space Balls
