John6012 wrote:I am in the process of hanging my doors on the TD and have potential problem. If I put the 1" T moulding on all four edges of the door, on the hinge side it "snags". I wonder if I should cut off one of the legs on the T moulding so the door would fit snugly? If I did so, it would create a potential problem with water entry? Any suggestions? Thanks
Podunkfla wrote:How about an "L" shaped molding on both sides under the hinge? Then you could still use insulation foam strip.
