You would be proud of me....
Postby Juneaudave » Sun Oct 01, 2006 1:20 pm
Big weekend for me. Got from here....
to here...
Now if someone would just clean my garage!!!
:cry: :cry:
Juneaudave
Images: 380
Postby dwgriff1 » Sun Oct 01, 2006 3:47 pm
I was by your house last week. Shucks, if I had known you needed help, I'd have stopped in, of course I would.
idahodave
dwgriff1
Postby mikeschn » Sun Oct 01, 2006 4:28 pm
Well, I can't help with your garage, but if you swing by with your trailer, I can help you put a floor on it!
8)
Postby Juneaudave » Sun Oct 01, 2006 4:59 pm
mikeschn wrote:Well, I can't help with your garage, but if you swing by with your trailer, I can help you put a floor on it!
8)
Just musing...but the next question for me is "How light can I go on a 5 x10 floor?" and not stay awake at night.
Here is some of my thoughts....
I bought 1/4 inch trailer deck screws to secure the plywood to the frame. Seems to me, if you secure the deck to the frame with those screws, you end up with pretty much the composite deck/floor system that has to add quite a bit of strength.
In my mind, MJ might have hit on the right combination with 5/8 ply fastened directly to the frame with deck screws. I think that makes sense but...
I also have 20 yds of 4 oz of 60 inch wide fiberglass and 3 gal of epoxy. I was thinking of a floor with a 3/4 pine frame and decked with 1/2 ply glassed on both sides. I think it would be pretty strong, but wonder if I would save any weight with all that glass. It would evidently cost more but I have the supplies.
Thoughts on a lightweight deck? Thanks...Juneaudave
Juneaudave
Images: 380
Postby mikeschn » Sun Oct 01, 2006 5:01 pm
I used 1/2" luan on the floor for the EH, and it's lightweight and strong.
Postby toypusher » Sun Oct 01, 2006 5:10 pm
If you want to put in insulation, then use 1/4" skins and 3/4" framing between.! Should still be pretty light. Or just use 1/8" on the bottom side since it does not have to support any weight, but would add to the strength of the overall floor system.
toypusher
Images: 324
Postby Juneaudave » Wed Oct 04, 2006 12:31 am
Now I'm moving into the "clamp farm" stage. Got a nice crop going for whatever I'm up to....
Juneaudave
Images: 380
