asianflava wrote:I have 8 5/8in bolts that go thru the floor and thru the square tubing.
Nitetimes wrote:asianflava wrote:I have 8 5/8in bolts that go thru the floor and thru the square tubing.
WOW !!! You haulin coal in there or what??? Or are those regulation hurricane straps.
asianflava wrote:Nitetimes wrote:asianflava wrote:I have 8 5/8in bolts that go thru the floor and thru the square tubing.
You know it's a good thing you posted that. I was going by memory, I think I may have used the 5/8in bolts to hold the coupler to the tongue. 5/8 just seemd to come to mind. Probably because those were the ones that I had to buy most recently (after I cut the tongue down).
The ones I used to bolt the body to the frame have a 9/16in head which probably means that they have a 7/16in shank? or is that a 3/8in shank?
Kevin A wrote:asianflava wrote:Nitetimes wrote:asianflava wrote:I have 8 5/8in bolts that go thru the floor and thru the square tubing.
Rocky,
3/8" bolts generally have a 9/16" head. Are you sure you used a 5/8" bolt on the coupler and not a 7/16" bolt with a 5/8" head? a 5/8" bolt is a rather large bolt to be using on a teardrop trailer
I used something similar to these when I attached the plywood floor to the trailer frame,
http://www.stainless-fasteners.com/self ... screws.htm
Nitetimes wrote:BTW Rocky, I kinda figured that's what you meant. Just jerkin yer chain a bit.![]()
KA wrote:Is there any concern about structural strength loss by drilling into the frame?
