jplock wrote:I don't plan on spending a lot of time inside, it is mostly for sleeping. I did get a little portable AM / FM radio. Mine is a woody so an external antena is not needed. I am going to use a 6 volt regulator hooked to my 12 volt trailer battery buss in my power panel. That will plug into the external DC auxilary power connector on the radio. The regulator is availabe from Radio Shack, and it is voltage adjustable from 0 to 12 VDC.
jplock
Micro469 wrote:
Why do you need a regulator to run a 12 volt car radio???
I'll hazard a guess that his portable am/fm radio runs on four 1.5 volt batteries and he is using the voltage regulator to supply 6 volts to the radio.
jplock
jplock wrote:This in a nut shell is what this panel does.
Nytewyng wrote:Some day soon Ill have one of these for my TD. I like the vintage look and since most campsites we go to have electric this will do just fine, Check out the web site they have some cool vintage look radios with cd palyers built in as well.
http://tinyurl.com/yybpn3
jplock
