BTW I LOVE your pics of Mr. Diesel....
Kevin A wrote:Skip, what does the spitfire use for hood supports while in the open position? I tried to locate it in the blown up view but my eyes just aren't what they used to be.
madjack wrote:to keep the hurricane hinge from sliding...
madjack wrote:to keep the hurricane hinge from sliding...1) cut the hinge so that it is 1" longer overall than the width of the tear...this will act a deflector to keep rain water from running into the galley 2) on the hatch portion of the hinge, cut it off so that it is 1/2" shorter overall than the body portion 3) drill a hole in the body portion of the hinge barrel 1/8th" from the ends and run a small screw down into the hole after mounting is complete...this will keep the hinge from sliding and from leaking....
Steve Frederick wrote:madjack wrote:to keep the hurricane hinge from sliding...1) cut the hinge so that it is 1" longer overall than the width of the tear...this will act a deflector to keep rain water from running into the galley 2) on the hatch portion of the hinge, cut it off so that it is 1/2" shorter overall than the body portion 3) drill a hole in the body portion of the hinge barrel 1/8th" from the ends and run a small screw down into the hole after mounting is complete...this will keep the hinge from sliding and from leaking....
Wow Jack![]()
That's a great idea!
I used the 1/8" spacer method Rocky mentioned. The hatch will rub if it gets off-center. Your idea would limit that issue. On future builds, I'll use a 1/4" space though! Funny, how we keep learning new tricks!!
madjack wrote:Steve, whenever we quit learning, it is time to give ALL up...that makes this site a real LIFEsaver![]()
Ira wrote:You're supposed to leave space?
asianflava wrote:Hey Ira get this:
I wanted more headroom for the hatch. I didn't want to mess with the hatch struts so what did I do? I cut off the bottom of the hatch. It isn't much but it did 2 things, I gained about an inch, plus now when you hit your head on it, you will hit a flat instead of a corner.
