CPASPARKS wrote:Sorry Heikki,
My stoves use propane...I am not familiar with your available fuel over in Finland...
CPASPARKS wrote:Howdy Heikki,
I was thinking that I read one of your posts a long time ago about propane. Are the 1lb disposable canisters readily available where you live(camp)???
Let me know...I will have a good suggestion for you. Compact as well.
Sonetpro wrote:I don't know how your wife is. But mine will not light one unless it has a pushbutton starter.
Dale M. wrote:IF you are looking at a LPG (Liquid Petroleum Gas) stove, I would look at "connectivity" to a bulk tank.... The 1 pound (US) cylinders get awful expensive after a while. So connecting to a bulk tank (20 pound - or what ever size is popular in your country) may be something to consider....
Connections at stove vary from manufacture to manufacturer, each can have own proprietary connection. Also US LPG connectors are probably different than European so that is consideration...
I personally like the nostalgia of the old 2 burner cast iron stoves (or reproduction) styles. Note that these styles do need a wind screen in most cases... But since I have later design (Coleman) LP gas stove and bulk hose and tank, I will probably stay with that....
I am also not too excited about handling liquid fuels when traveling or filling stove. no matter how careful one is, some always gets spilled...
This threads takes me back to this discussion...
http://tnttt.com/viewto ... opane+hose
Dale
