Best connector to Tap-In to a wire?
Anything electric, AC or DC
Best connector . . . .
Postby rooster » Wed Oct 18, 2006 1:57 pm
When I wired my tear and made a splice to branch off to my porch light I did the same as Danny did, I soldered and taped them. With wires inside the walls and ceiling I did'nt need shorting out problems. It worked for me . . . .
Jim, :thumbsup:
Beware of what she wishes....especially with that twinkle in her eye and that mischievious smile....you know it's gonna cost....
rooster
Images: 42
Postby asianflava » Wed Oct 18, 2006 3:33 pm
Those Scotch Locks are crap. When I used to install car stereos, the alarms would include those taps, we would toss them. You are better off using a butt connector and crimping 2 wires to one end and one wire to the other end.
asianflava
Postby halfdome, Danny » Wed Oct 18, 2006 5:00 pm
greasywheats wrote:Yikes- 12 circuits! either you have a lot of expansion space or you are remotely controlling the US satellite program from your teardrop! 8)
I am definitely going to add an auxiliary panel for my remaining fixtures.
Every light & 12 volt plug has it's own circuit and I have some extras. You can never have too many the way I look at it. :) Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Sonetpro » Wed Oct 18, 2006 7:27 pm
I used the marine panel also. 6 circuits.
If I was going to splice I would only solder and shrink tube. I hate electric problems.
Sonetpro
Images: 107
Postby bdosborn » Wed Oct 18, 2006 8:42 pm
An easy way to join multiple wires together is to use push-in connectors:
Depends on who you talk as to how good they are. I get everything from they're the best to they're the worst. I used them on my trailer but only in spots where I could get to them and only on grounds so I could evaluate them over time. Everything else is soldered and heat shrinked. So far I haven't had any failures. They're called "wagos" in the field and are available at Home Depot. Made by Wago (who would have figured?) and Ideal.
Images: 806
Postby bdosborn » Wed Oct 18, 2006 8:56 pm
asianflava wrote:Those Scotch Locks are crap. \
I agree. They nick the conductors so they break over time and they let all kinds of corrosion in through the cut in the insulation. Throw them away!
Images: 806
Postby Dale M. » Wed Oct 18, 2006 10:23 pm
Several companies makes a "closed end" connector which is a metal sleeve inside a plastic shell... Generally used in AC wiring work for bonding ground connectors....
Usually available anywhere wiring products are sold.... You just cut main wire and strip both ends, and strip end of branch wire, and insert all three into in connector and crimp.....
http://order.waytekwire.com/IMAGES/M37/ ... 19_027.PDF
Part numbers #37020 thru #37025
Dale
Dale M.
Images: 18
Postby kayakrguy » Tue Nov 07, 2006 5:32 am
Boaters world has 3 way crimp connectors which could also be shrink wrapped if you wanted..
http://www.boatersworld.com/product/199321886msk.htm
There are also some here:
http://shop.genuinedealz.com/items/item ... id=3926595
Jim
A disposition to preserve, and an ability to improve, taken together, would be my standard of a statesman...
But what is liberty without wisdom, and without virtue? It is the greatest of all possible evils; for it is folly, vice, and madness, without tuition or restraint.
Edmund Burke
kayakrguy
Images: 195
Postby greasywheats » Tue Nov 07, 2006 11:09 am
Kayakerguyer & All-
Thanks for all the input- those ring connectors look great to me. My soldering skills allow me to properly tin the wire ends and solder the terminals to the wire ends, but my attempts at soldering a wire onto a spliced wire have turned out pretty chunky. I think I feel safer with mechanical connections and some solder and elctrical tape.
Thanks Again!
greasywheats
Images: 25
Postby Dale M. » Tue Nov 07, 2006 11:12 am
kayakrguy wrote:Boaters world has 3 way crimp connectors which could also be shrink wrapped if you wanted..
Jim
Although they are electrically effective and easy to work with, they create a nightmare to insulate with either tape or heatshrink and create excessive bulk in any wiring system.... I avoid then at all cost....
Dale
Dale M.
Images: 18
Postby Dale M. » Tue Nov 07, 2006 11:15 am
greasywheats wrote:Kayakerguyer & All-
Thanks Again!
Chunky solder splices are caused by not forming wire "splice" correctly and not using enough heat to solder splice.... A soldered splice should not be any larger than the initial mechanical splice before soldering...
Dale
Dale M.
Images: 18
Postby kayakrguy » Wed Nov 08, 2006 8:20 am
[[/quote]
Dale[/quote]
Dale,
Why are they any harder to heat shrink than any other connector?
Jim
Edmund Burke
kayakrguy
Images: 195
Postby Dale M. » Wed Nov 08, 2006 10:52 am
Dale,
Jim
Because you have to use a huge tube to slide over the "T" shape of connector...... Heat shrink will only shrink a certain percentage ... IF you have to use a large tube to get over initial shape, it may not shrink enough to actually seal air and moisture from connection and may allow stray metallic object to enter into gap and cause a problem....
Dale
Dale M.
Images: 18
Postby kayakrguy » Wed Nov 08, 2006 11:35 am
Dale,
Why put the shrink over the Y ? I would simply heat shrink each of the individual joints...just like I would with a regular two wire connection. I see no need to shrink on the center connector....
Jim
Edmund Burke
kayakrguy
Images: 195
Postby asianflava » Wed Nov 08, 2006 2:46 pm
For my trailer lighting (turn, brake, stop) I used wire nuts, Gasp! They aeren't your traditional wire nuts though. The wries go thru a ring, and the wire nut threads onto the ring so the wires are locked into place, they work pretty well for me. I've also seen water resistant versions of this connector. It is basically the same thing except it is filled with what looks like grease.
I will probably have to remove my fenders so I needed a way to disconnect them without having to cut the wire every time.
asianflava
Return to Electrical Secrets
