PS: please excuse the white color, I did not paint them yet!
mikeschn wrote:Bigger wheels? Something like this?
Just kidding!
tinyshiny wrote:Sorry, I'm sure this is somewhere but I couldn't find it. I like the price of the HF trailers, but hate the tiny wheels. The coolest teardrops seem to have bigger tires with fenders.
Is there anyway to upgrade those to bigger 14 or 15 inch wheels?
Thanks
Dave
Dale M. wrote:You can probably aquire all the materials and cut them to fit, then hire a "welder on wheels" to come by and zap it all together. Materials for my frame, all the steel, coupler, springs, axles stubs, hubs and wheels and tires ran me about $350....
Dale
Longrifle Joe wrote:Many years ago, I built a trailer to haul birddogs. I used angle iron for the frame and had a friend weld it---but more to the point of your inquiry, I found an old Ford Falcon that had been junked, removed the front spindles and bought a piece of pipe the correct diameter and length, and had my friend weld those spindles into the pipe. Gave me an axle the exact width I wanted with the exact wheelsize etc. I wanted. I hauled that trailer all over the Southeastern USA with nary a problem, many thousands of miles.
Just a suggestion, but find a junker with the bolt pattern you want, remove the front spindles and weld them into a pipe the right size. Gives you a sturdy axle. As I recall, I used leaf springs from the rear end of another junked car and simply had hanger brackets welded into the frame----was cheap and worked for me.
Joe
mikeschn wrote:You're talking about this one, right?
