Weather is wonderful in Houston today.
I'll get the outside trim installed on the camper after another coat of paint.
Elumia wrote:The wide band should be the contrasting color with thinner bands black.
Hudsonite wrote:Steve, you may have indicated this before and I missed it. Where did you get the black trim you used on the outside?
steve wolverton wrote:Hudsonite wrote:Steve, you may have indicated this before and I missed it. Where did you get the black trim you used on the outside?
It's a garage door seal purchased from Lowes.It runs about $15 for 16 feet. Lowes has the nice foam rubber seal, Home Depot has a flat, thin seal.
I used construction adhesive to attach it and sealed the edges with clear silicone sealant.
Jimbo wrote:Since you used the cloth and epoxy, is the seal even necessary or is it just for looks ?
