Mary K wrote:Red Trailer Mod.
Just wanted to show yall the plate I added under the axle. The axle has a notch cut into it for a bolt head on the springs. (on both sides left/right) When the trailer is modified for the Generic Benroy Plans these notches do not line up. I added this plate w/ a hole for the bolt to lift the axle off the bolt head.
Mk
Gerdo wrote:I think tie bolt that you are talking about, it goes thru the leaf spring pack, not only holds the pack together but it is also a locating pin. It puts the axle in alignment and keeps it there.You may want to remove your shim and drill a hole for the bolt.
