I received my foot warmer/ stand up heat panel today and it seems to work great even on my 400 watt inverter. There is no exposed wires and you can actually put your feet on it if you like. I can touch it momentarily, since on high it is 140 deg and 120 deg on low. I like the idea of a heater that gives off no fumes, doesn't consume oxygen etc. I have a digital temperature gauge in the TD and with the heater on it got to 70 deg from about 58 deg in 90 minutes or less. More pictures in my album.
Antenna
