What is the best Goop?
Postby NightCap » Sat Nov 18, 2006 3:31 pm
I've looked through the forum and find myself still wondering what the best goop to put under the "Better-Than-Hurricane" Leak proof Galley Lid Hinge? it will be attached to wood and not aluminum. What Caulk will hold up longer in the sun snow and rain? :baby:
#1 - 100% Done #2 - 100% Done Thinking about #3
NightCap
Images: 259
Re: What is the best Goop?
Postby mikeschn » Sat Nov 18, 2006 5:13 pm
NightCap wrote:I've looked through the forum and find myself still wondering what the best goop to put under the "Better-Than-Hurricane" Leak proof Galley Lid Hinge? it will be attached to wood and not aluminum. What Caulk will hold up longer in the sun snow and rain? :baby:
I used Lexel on my last build and its holding up really well...
http://www.kk.org/cooltools/archives/001446.php
Postby Podunkfla » Sat Nov 18, 2006 5:40 pm
I'd hafta go with "PL Urethane" ... they even make a light gray that is almost aluminum color. Best stuff I've found. I've caulked chemney flashing and skylights with it for at least 7 years. None have ever failed. :thumbsup:
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby Miriam C. » Sat Nov 18, 2006 7:35 pm
Hey Mike
How much of the Lextel did you need to do the hinge?
Postby Jiminsav » Sat Nov 18, 2006 8:29 pm
if it's under the hinge, and out of the sun, it don't matter what you use..it will last a long time..I used aluminum colored silicon caulk..looks good, lasts a long time.
Jim in Savannah
Jiminsav
Images: 40
Postby NightCap » Sat Nov 18, 2006 8:32 pm
Thanks all. That arms me with some info before I hit Lowes or Home Depot.
NightCap
Images: 259
Postby mikeschn » Sat Nov 18, 2006 8:35 pm
Is that a trick question?
I just put a generous bead under the hinge, and cleaned up the excess that squeezed out.
I probably squeezed the trigger a few times. So what is that? 1/16th of the tube? I used a full sized tube like this... and have plenty left over...
Miriam C. wrote:Hey Mike
Postby Podunkfla » Sat Nov 18, 2006 8:37 pm
Jiminsav wrote:if it's under the hinge, and out of the sun, it don't matter what you use..it will last a long time..I used aluminum colored silicon caulk..looks good, lasts a long time.
Yep... I agree Jim. I've been thinkin about just using a stainless piano hinge for the galley hatch with a strip of urethane over it held down with aluminum or even wood trim? Seems to me you don't need an expensive hinge if it is waterproofed like that. Shoot... "shower pan liner" would prolly last a few years even though it wasn't made for outdoor use... and it's cheap. (My ex always said "cheap was my middle name") :lol:
<B>~ Brick
Podunkfla
ol' noodle haid
Images: 5
Postby Miriam C. » Sat Nov 18, 2006 9:06 pm
mikeschn wrote:Is that a trick question?
No it is not a trick question. The URL went to a picture of a small squeeze tube. Wondered if if was enough. :R I guess the big one would get all the other sealing issues done. 8)
Postby Jiminsav » Sat Nov 18, 2006 9:57 pm
Brick, take my word for it..buy the hurricane hinge from Grant and slap it on there..it's well worth the cost..my first one I did with a piano hinge and inner tube cover and it always leaked.
I'm a cheap bastard too, but some things require money to make your life easier.
Jim in Savannah
Jiminsav
Images: 40
