I did not realize that I built my first TD in less than 200 posts!!!!!!!!!
I'm getting a couple of bubbles under the surface of my doors.
Any suggested fix?
I'm thinking of injecting some white glue!
Steve_Cox wrote: Let this be a warning to others. The bubbles are no doubt gas bubbles from the inferior, bacteria laden glue used in foreign plywood. If you lay down in the trailer and be very quiet can you hear the plywood delaminating? Sounds just like Rice Crispies
That and the fact that he should have spent more than $12.95 for a sheet of ply.:yes:Steve_Cox wrote:This never would have happened if you had made more than 200 posts. Let this be a warning to others.
How about that. I've learned something this week and the week has just started. Now I can take the rest of the week off and not worry about learning something new this week.Steve_Cox also wrote:The bubbles are no doubt gas bubbles from the inferior, bacteria laden glue used in foreign plywood. If you lay down in the trailer and be very quiet can you hear the plywood delaminating? Sounds just like Rice Crispies
asianflava wrote:Yeah Yeah poke it with a stick!
Bandit wrote:Let me further explain. I did not use plywood, I used the 3/4" veneer with the slick mahogany finish. I can not remember the name. It is not ChiPly, it is SouthAmPly/Veneer.
It is also painted with Marine Epoxy, so I do not feel that water leaks are the issue.
This has not happened anywhere else.
And it was $24.00 per sheet thank you!
Worse case scenario is that I make new doors, no problem.
It is stored in an outbuilding at my shop.
