sandman wrote:hey Guys,
I am trying to assemble my new Red Trailer 5x8 and I keep running into a problem. The main outer frame pieces are not labelled correctly and I it's driving me nuts. I have 1 piece marked RL, RT, 1RR, and another 1RR. I find myself being made a fool of by the chinese guy that put the stickers on. Where do they go? My box was destroyed and the instructions were missing. I looked on the site at the manauls online and my parts are not labelled even close.
Another question, do I have to cut the two metal crossmembers that get placed longitudally in the outer rails? Can I just install them without cutting? Will I have to drill holes or will they line up? I am so flustered I can't even look at the trailer parts on my garage floor after 2 wasted hours trying to figure this thing out.
sandman wrote:Thanks for the reply, MaryK. That helps quite a bit. I appreciate the pics too. I am a very visual person so pics go a long way. Do you remember how much you cut off the 2 rails that get placed into the side rails? I have no clue how much to cut off, which end to cut. There's holes everywhere and not sure which ones to use and which to ignore.
sandman wrote:I am trying to assemble my new Red Trailer 5x8 and I keep running into a problem. The main outer frame pieces are not labelled correctly and I it's driving me nuts. I have 1 piece marked RL, RT, 1RR, and another 1RR.
sandman wrote:Now that you said that, I DO have two of the same 1RR pieces. My trailer doesn't look right. The left and right side bolt holes are all different. I just contacted Red Trailers about sending me the correct piece which should be 1RL. This has been an utter pain in the butt. How long did it take for them to ship you the replacement piece?
