Wheel hold water in tire carrier
Postby Gage » Sun Nov 26, 2006 12:00 am
Forget about the full size chrome wheel and put a donut up in there and don't worry about it. It's only suppose to be a spare to get you where you can get the flat fixed. K.I.S.S.
No body is going to see the spare under the teardrop.
Image Image Image
Gage
Images: 28
Postby asianflava » Sun Nov 26, 2006 1:26 am
My spare isn't even the same size as the other 2 wheels. I have 175/75-14s on the tear but my spare is an El Cheapo 12in trailer wheel/tire from Wally World. As long as it gets me to the next repair place, I'm fine with it. Plus, it doesn't take up as much room as the tires on the trailer.
asianflava
Postby madjack » Sun Nov 26, 2006 1:43 am
...they might if they were sleeping onna speed bump :lol: ;) ........................................ 8)
Postby PaulC » Sun Nov 26, 2006 5:14 am
Gage wrote:Forget about the full size chrome wheel and put a donut up in there and don't worry about it. It's only suppose to be a spare to get you where you can get the flat fixed. K.I.S.S.
Have a nice Day 8)
Cheers
Paul :thumbsup:
PaulC
3rd Teardrop Club
Images: 36
Postby Gaston » Wed Nov 29, 2006 4:55 pm
Go to the junk yard and pick up one of the "temp" spares from what ever car mfg. that fits your lug size (if its 5 on 4 1/2 the temp spare from a mid size GM fits, I'm useing a Buick Century) I mean why would you want to abuse a nice crome wheel and moon cap by hanging it under a trailer??? :cry:
a spare is to hold up the side of the trailer in case of a flat, not to look pretty ;)
The difficult we do now... the impossible takes a little longer
Gaston
Images: 98
Postby Classic Finn » Wed Nov 29, 2006 7:55 pm
Gaston wrote:Go to the junk yard and pick up one of the "temp" spares from what ever car mfg. that fits your lug size (if its 5 on 4 1/2 the temp spare from a mid size GM fits, I'm useing a Buick Century) I mean why would you want to abuse a nice crome wheel and moon cap by hanging it under a trailer??? :cry:
I dont think Id want to hide my whitewall and smoothie wheel under there..sort of a waste ...besides who,s going to crawl under there and look and say.... Wow I like that wheel.... :lol: :lol:
Ohhh Well...
Classic Finn
Classic Finn
Midnight Sun Voyager
Images: 146
Spare
Postby Lesbest » Wed Nov 29, 2006 8:16 pm
Don't worry about the water, if you drive in ANY dusty conditions the low spots will fill with dirt. EVERY spare I ever took out of a blazer, astro van,ranger........ anything mounted under the vehicle was filled with a dirt, dust, gravel mix that had to be scraped out to get to the rusty lug holes. Water might not splash up there but if air circulates around it DIRTY air can circulate in it. Just a muddt thought.
Les
Music is like chocolate.......you can't really enjoy it unless the rappers are gone.
Lesbest
Images: 7
Re: Spare
Postby Juneaudave » Wed Nov 29, 2006 8:38 pm
Lesbest wrote:Don't worry about the water, if you drive in ANY dusty conditions the low spots will fill with dirt. EVERY spare I ever took out of a blazer, astro van,ranger........ anything mounted under the vehicle was filled with a dirt, dust, gravel mix that had to be scraped out to get to the rusty lug holes. Water might not splash up there but if air circulates around it DIRTY air can circulate in it. Just a muddt thought.
Les
After much hand wringing, I came to the same conclusion. If I had to do it over, I would use a donut or better yet, match the tires and rims with the tow vehicle.
But...I have $150 bucks in that spare (call it pride of pocketbook), you don't have a gas station on every interchange here in Alaska to fix a flat, and I've already built the hanger and set the axle position in consideration of the weight and placement of that thing...so I'm just moving on.
:M :M Don't worry, be happy :M :M
Juneaudave
Images: 380
Re: Spare
Postby halfdome, Danny » Wed Nov 29, 2006 10:48 pm
Juneaudave wrote:I have $150 bucks in that spare (call it pride of pocketbook), you don't have a gas station on every interchange here in Alaska to fix a flat, and I've already built the hanger and set the axle position in consideration of the weight and placement of that thing...so I'm just moving on.
Wow :? Tires and rims are sure expensive in Alaska $> $> . I basically have the same spare and it was somewhere around $75 for the whole shebang. Got a donut for $10.00 and keep the smoothie in the garage. I guess I'll just rotate all three. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Re: Spare
Postby Gage » Wed Nov 29, 2006 11:39 pm
Well, beings how you have money to burn and you like to charge forward without thinking and then ask the board how to fix something but don't really want the advice given. Why don't you try ebay for a cover. The one below is only $1.95. A course shipping is $65.00, but who cares.
You don't have a gas station at every interchange here in the High Desert either.
Image Image Image
Gage
Images: 28
Re: Spare
Postby Juneaudave » Wed Nov 29, 2006 11:42 pm
I know...I want to cry :cry:
But it was $70 bucks to special order the rim and another $80 for the 205/75-15 tire. Funny thing, I was so excited about doing a build, I ordered the tires and rims the same day I ordered the axle with absolutely no plans, just a vision of what I wanted. With 20/20 hindsight, probably not the most inexpensive way to do things....BTW....did you heat up that tear with an electric heater to see if you had less condensation?
Juneaudave
Images: 380
Re: Spare
Postby halfdome, Danny » Wed Nov 29, 2006 11:56 pm
Juneaudave wrote:.BTW....did you heat up that tear with an electric heater to see if you had less condensation?
Yes, that must have been the problem. As soon as this %$#@&^ snow melts I'll take the tear to my shop and wire it for 110 volt. Right now I have to let the cord hang out the door to heat the tear but it heats up very fast. Thanks for the suggestion. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Juneaudave » Thu Nov 30, 2006 2:10 am
Pretty harsh there Gage...I can't figure it out from your posts...should I spend some money or not???? $150 for a new tire and chrome rim didn't seem like such a bad price here in Juneau for what I wanted. I thought I carefully considered and valued the advice given in my post...Oh well...I guess I still have a year to go and $4850 left to go in my build before I match you.
I've got over $5000 in my teardrop. I didn't build it on a budget. I built it like I wanted it and as the money came. A two and a half year build and there is nothing that I would do different. When I finished it, I stood back, took a look and said "yep, that'll work".
He who builds a cheap trailer will always be unsatisfied. Think about it.
Juneaudave
Images: 380
Postby Leon » Thu Nov 30, 2006 2:29 am
Juneaudave wrote: I still have a year to go and $4850 left to go in my build before I match you.
If you spent $150 for the spare and have $4850 to go, then how did you get the rest of the stuff on your build? :thinking:
Leon
Images: 21
Postby Gage » Thu Nov 30, 2006 3:28 am
Naw, First part was just being straight forward with the humer. And the second part was a sound direction. What I would like to know, is where did you pick up that torsion axle for free. I'm getting ready to build another teardrop and free is good.
Maybe I should get back to using the emoticons.
Image Image Image
Gage
Images: 28
Users browsing this forum: Google [Bot] and 0 guests
