What Are Your Favorite Clamps?
Re: NOT my Favorite Clamps
Postby Kevin A » Sat May 28, 2005 11:52 pm
Dee Bee wrote:I used c clamps in my build occassionally. But what I really wanted to share is that I also used a set of spring clamps from Harbor Freight Tools. I broke 4 of them so far. The plastic handles broke off the fulcrum. Of the remaining ones half of the pivot pads at the buisness end of the clamp have broken off.
I only paid 9 buck for the complete set of 12. I gues it proves the point you get what you pay for...
They served their purpose, and I will be able to finish the build without buying any more. Would I buy HF plastic clamps again? Probably not.
DEE BEE
Was it this type of clamp? http://www.harborfreight.com/cpi/ctaf/Displayitem.taf?itemnumber=36277 I've had really good luck with mine so far, the first time I used them on my trailer was on the trip home with it. Here's a shot of two clamps holding the window closed on the trip home from Shasta, CA.
Kevin A
The other guy
Images: 289
Postby McTeardrops » Sun May 29, 2005 7:24 am
I don't know if you'd properly call this a clamp, but this hold-down did come in handy attaching the ply to the hatch frame
Lenny
[email protected]
I've reached the stage, in life, where my foam has more memory than I do!
McTeardrops
Postby Arne » Sun May 29, 2005 7:58 am
I use the h/f plastic clamps extensively in modeling, the small ones...
I find the large ones too slippery. I do use large spring clamps that are metal with plastic coverings on the jaws (also from h/f years ago)... the plastic covering on them is quite 'sticky' and does not slip easily.... and I use them on all types of projects, I think I have 3 different sizes.
One of the neatest uses is on vertical surfaces as braces to hold shelves in place while I drill holes... they are not used as clamps, but as supports to keep the shelves from dropping.....
I much prefer the metal clamps with the plastic coating on the jaws and handles.... I would not buy the large plastic clamps.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby Kevin A » Sun May 29, 2005 11:43 pm
More "gravity clamps"
Kevin A
The other guy
Images: 289
Postby jplock » Tue Dec 05, 2006 11:22 pm
Here is inexpensive Homemade PVC pipe C Clamps.
Keep smiling!
jplock
Images: 233
Postby Juneaudave » Wed Dec 06, 2006 12:05 am
I like the PVC clamps...but my favorite clamps are a package of shims for $3.98 cents
Look Mom...no screws 8)
Juneaudave
Images: 380
Postby bledsoe3 » Wed Dec 06, 2006 3:11 am
I see you have Ira's favorite red clamp too. :beer:
bledsoe3
Images: 112
Postby b.bodemer » Wed Dec 06, 2006 1:13 pm
My favorites include anything and everything that will do the job: :thumbsup:
Since I was working over at Bill's house he had all sorts of clamps for each step of the build! :)
Barb
b.bodemer
Images: 328
Postby bledsoe3 » Thu Dec 07, 2006 2:31 am
You can never have too many clamps.
You also can't beat the price on Harbor Freight clamps.
bledsoe3
Images: 112
