I was hoping I could get some help. I've never wired 110 before and I'm not real sure what I'm doing. Here is what I've got so far...
Ok, now I removed the knockout on the top right corner. The wire from the power pole at the campsite will feed in there. Ok, so I'm guessing that the hot wire (the black wire) will go to #2 and that will feed the breakers. The neutral (white wire) will go to #3. The ground wire (green) will go to #4. Is this right?
So next I install the #12 wire and punch out another knockout. Ok, so if I'm close, then the hot wires (black) will go from #1 breakers to the outlets & one to the AC. I'm guessing the ground (green) will feed out from the #4 as well. Here's where I'm confused, where do I get my neutral wire? If it goes into #3, where does it come out for the outlets and stuff? I hope this makes sense as I really don't know much about this stuff.
Thanks.
