Building your own water tank
Postby Jiminsav » Sun Feb 06, 2005 9:56 am
Dean, you can pressurize PVC up to at least 50 PSI without any problems, but you better be sure your glue joints are good..as for sputter, that will only happen if the water level gets down to the spigot..so a full tank will start off with 50 PSI and then the pressure would decress as you use water, but it should be enough to push all the water out with a good flow.
this is assuming the spigot is at the lowest level.
Jim in Savannah
Jiminsav
Images: 40
Postby BrianB » Sun Feb 06, 2005 10:10 am
It's actually against code here to use exposed PVC for pressurized water.
An electric or manual pump just seems so much simpler (and safer).
BrianB
Postby Jiminsav » Sun Feb 06, 2005 3:18 pm
so cover it up.
Jim in Savannah
Jiminsav
Images: 40
Postby BrianB » Sun Feb 06, 2005 3:31 pm
Exposed meaning not underground or encased in concrete.
BrianB
Postby surveytech » Fri Dec 15, 2006 1:07 pm
Has anyone else made a water tank out of PVC and if so are you satisfied with it?
Just curious........thanks!
surveytech
Images: 6
Postby madjack » Fri Dec 15, 2006 1:20 pm
...yes and yes...7'+ of 4" PVC sch 40, which holds just short of 5gals...click on my WWW button for pics of said tank...used a 25buck pump/faucet combp from JCWhitney onit.....
madjack 8)
p.s. water tank capacity calculator click here
Postby Micro469 » Fri Dec 15, 2006 3:49 pm
madjack wrote:...yes and yes...7'+ of 4" PVC sch 40, which holds just short of 5gals...click on my WWW button for pics of said tank...used a 25buck pump/faucet combp from JCWhitney onit.....
madjack 8)
where are the plans for it again?? :oops:
John
Micro469
Images: 382
Postby surveytech » Fri Dec 15, 2006 4:16 pm
madjack 8)
MJ you are the man! that looks good! I may steal you idea.....hehe.
Where is it installed and where is the fill? I cant seem to find those photos.
Thanks!
surveytech
Images: 6
Postby wa_flyfisher » Fri Dec 15, 2006 4:41 pm
Being in the engineering field I would suggest using CPVC, which is rated at potable water, standard PVC and ABS isn't.
My last house was completely plumbed with CPVC for all supply water lines and ABS for waste.
http://www.ppfahome.org/cpvc.html
wa_flyfisher
Postby Jst83 » Fri Dec 15, 2006 6:01 pm
I bet that the PVC pipe idea would be a good idea for waste water from the sink also. Where do most pepole drain there water to from the sink?
Jst83
Images: 215
Postby jplock » Fri Dec 15, 2006 7:22 pm
This seems to be big assortment of water tanks. I think I may go with the 11 gallon model Part: R-RV14W.
Website
http://www.tank-depot.com/product.aspx?id=162
jplock
Keep smiling!
jplock
Images: 233
Postby paddlehead » Fri Dec 15, 2006 7:39 pm
Brian,
Assuming the ID of the pipe is 4", then a 4' section would hold about 2.61 gallons and weigh a bit over 22#, plus weight of the pipe. Your 2' section would hold half that amount.
Area of a circle is π r^2 (Pi x r squared).
3.1416 x 2 x 2 = 12.57
12.57 x 24 = 301.6 cubic inches or about 1.31 gallons. A 48" length would hold double that.
Don
paddlehead
Images: 63
Postby paddlehead » Fri Dec 15, 2006 7:43 pm
My apologies, I seem to have stumbled into an old discussion and didn't read the details in the thread before I responded.
Don
paddlehead
Images: 63
Postby BrwBier » Sat Dec 16, 2006 12:12 am
Fresh water tank and gray water tank
ImageEach holds about 7 gallons
BrwBier
Images: 100
Postby mikeschn » Sat Dec 16, 2006 6:26 am
How do you fill the fresh water tank?
