Hatch question
Hatch question
Postby dewayne » Fri Dec 29, 2006 10:12 am
Should the top cross spar on the hatch also be oak for the other part of hinge to be screwed to also? All my other spars on the hatch will probably made from 2 pieces of 3/8 arauck (spell) ply laminated together witch will make each piece approximatly 7/8".
All suggestions appreciated.
dewayne
Pay it forward and the world would be a better place.
dewayne
Images: 25
Postby Juneaudave » Fri Dec 29, 2006 10:59 am
Juneaudave
Images: 380
Postby rbeemer » Fri Dec 29, 2006 11:05 am
Dewayne,
I think it depends on what side of the spar you are screwing into. If into the top of the plywood(side where you can only see one layer of wood) you should be okay. If you are screwing into the sides(where you can see the layers of the plywood) then there is a bigger chance for failure in having the screws pull out/loosen and I would use a piece of solid hardwood.
Remember there is more stress on these to spars than any other when you are opening and closing the hatch and the reason folks use oak(the world according to Rick) is that oak tends to not flex as much as any other and for it screw holding capabilities. You can use other hardwoods but I do no think you will finds a species as cheap as oak(again just Rick's opinion)
Rick
If ducks had scales, would fish quack?
rbeemer
Postby dewayne » Fri Dec 29, 2006 11:13 am
Thanks juneadave, I'm gluing as well as screwing so I will use oak for my 2 spars for the hatch hinge.
dewayne
dewayne
Images: 25
Postby halfdome, Danny » Fri Dec 29, 2006 12:25 pm
Red Oak is OK, White Oak is better but I used Eastern Rock Maple for both spars that hold the hurricane hinge and cabin door hinges.
:D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Gerdo » Fri Dec 29, 2006 1:02 pm
I also used Maple for anything of concern.
Gerdo
Images: 156
Postby Ira » Fri Dec 29, 2006 3:43 pm
Spars for the hatch?
Heck, you can use pine.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby asianflava » Fri Dec 29, 2006 4:18 pm
Ira wrote:Spars for the hatch?
I used 3/4in ply for my spars.
asianflava
Postby halfdome, Danny » Fri Dec 29, 2006 5:25 pm
I have as much use for pine for hinges as I do a cow pissin' on a flat rock. :lol: Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby seahorse » Fri Dec 29, 2006 8:49 pm
Oak or maple........both are hard wood , and will hold screws well.
seahorse
Images: 39
Postby Ira » Sat Dec 30, 2006 2:13 pm
IT'S A STUPID HATCH, FOR GOD'S SAKE!
WE'RE NOT BUILDING THE SPACE SHUTTLE HERE!
And I don't understand that metahphor at all.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby halfdome, Danny » Sat Dec 30, 2006 3:06 pm
Ira, Pine, Yellow is a soft weak wood in all strength properties with a specific gravity of .39
Red Oak has a medium bending strength and stiffness with high crushing strength with a specific gravity of .77
White Oak is the same with a specific gravity of .76
Rock Maple is high in all strength properties except stiffness which is medium with a specific gravity of .72
My reference is from "World Woods in Color" by William A. Lincoln
Specific gravity is a measurement of density of wood. Exceptionally light is .30 or less. Light is .30 - .45, Medium is .45 - .65, Heavy is .65 - .80, Very heavy is .80 - 1.0, & Exceptionally heavy (won't float in water ) 1.00
A cow pissin' on a flat rock will get you all wet if your standing close and most don't desire that. My garage man door is framed in fir, Douglas ( second or third growth ) with a specific gravity of .53 and the screws come loose more often than I desire. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby len19070 » Sat Dec 30, 2006 3:20 pm
Not to say anyones wrong or right.
But I use 5/4 yellow Pine for the hatch spar and the rest of the spars as well. That rear spar, no matter what its made of should be part of a larger convergence of several pieces of wood/plywood forming a beam. Once the roof sheathing, rear bulkhead plywood the interior cabinet and side walls are glued/screwed to it. Providing the hinge is done correctly and doesn't leak, Its never going to move-split or let 11 or 12, 1 1/2" screws come out.
Happy Trails
Len
len19070
Images: 24
Postby Ira » Sat Dec 30, 2006 4:38 pm
Yes you did.
:lol: :lol: :lol: :lol: :lol: :lol:
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby halfdome, Danny » Sat Dec 30, 2006 9:23 pm
Happy Trails
Len
For the few dollars you save and I spend I have a stronger insurance policy that all that hard work will last. Old growth pine is one thing but the stuff available today doesn't have the strength properties. The only time I ever use pine is when a customer specifies it for decorative purposes. :DDanny
halfdome, Danny
*Happy Camper
Images: 252
