Cast Iron Fry Pan; warped
Postby Arne » Wed Jan 03, 2007 5:59 pm
I have recently discoverd a couple of c/i fry pans in the basemant. They all are a bit warped in the middle from over heating, I guess... so, they don't sit flat on the stove... is there any magic way to re-flatten them? I would consider torching them and applying pressure, but not sure it would work.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Re: Cast Iron Fry Pan; warped
Postby Dee Bee » Wed Jan 03, 2007 7:05 pm
Arne wrote:I have recently discoverd a couple of c/i fry pans in the basemant. They all are a bit warped in the middle from over heating, I guess... so, they don't sit flat on the stove... is there any magic way to re-flatten them? I would consider torching them and applying pressure, but not sure it would work.
Nope. I think they are warped for good. They are called cast iron because they are cast in molds. If they warp due to uneven heating they permanently misshapen. They will still cook, even if they wobble....
Dee Bee
Grace happens...
Dee Bee
Images: 55
Postby Arne » Wed Jan 03, 2007 8:37 pm
thought so... should still be okay on a gas stove....
Arne
Mr. Subject Line
Images: 96
Postby Laredo » Wed Jan 03, 2007 10:19 pm
and fine on a campfire/charcoal, too.
How warped are they?
If they didn't cost you anything, you can try putting them in the oven on the "clean" cycle, then running out in the back yard and dropping them in a washtub of cold water.
Laredo
Postby Kevin A » Wed Jan 03, 2007 10:25 pm
Laredo wrote:and fine on a campfire/charcoal, too.
BAD, BAD don't ever put hot cast iron in cold water, unless you want a 2 piece skillet.
Kevin A
The other guy
Images: 289
Postby Arne » Wed Jan 03, 2007 10:30 pm
They are liveable.. each just has a warped slightly deep spot in the center, so they don't have that nice new flat bottom on them.... and they would rock a bit on a flat surface.
Arne
Mr. Subject Line
Images: 96
Postby Miriam C. » Wed Jan 03, 2007 10:45 pm
And don't ever put a real cold one on a real hot stove and leave it. :oops: Make this really neat twang sound and crack. :shock:
Postby Micro469 » Wed Jan 03, 2007 11:37 pm
Arne wrote:They are liveable.. each just has a warped slightly deep spot in the center, so they don't have that nice new flat bottom on them.... and they would rock a bit on a flat surface.
Hey!! At least your eggs won't spread out across the pan..... :lol:
John
Micro469
Images: 382
Postby Laredo » Thu Jan 04, 2007 12:14 am
there is that.... and they'll melt a tidy bit of marg for one of Lovejoy's instant meals, not too naff.
Laredo
