Ira wrote:And what hurts even more is that she's the sweetest girl in the whole wide world.
She's sweet because she knows, that you know that you don't have a chance. She can file you away as "one of the harmless ones" and can act like herself.
asianflava wrote:Ira wrote:And what hurts even more is that she's the sweetest girl in the whole wide world.
Arne wrote:Does anyone know if plain old wood glue will bond rigid pink insul to plywood, specifically if it is full coverage (spread with a roller).....
I plan on using hollow core design on the floor with same thickness foam in the spaces... the strength would be greatly increased if the foam becomes part of the structure, not just a filler material.....
sandman wrote:Hey Guys,
I am ready to install insulation on the bottom of my subfloor. What type would be best to use? The Pink Foam Board or the White EPS? Would be best to install it be spray adhesive and screws with fender washers?
