Both heaters have a built-in thermostat.
I don't want to install garage/shop furnace because that would require a vent to the outside.
The shop is already plumbed for natural gas and I already have 220V installed.
So either of the heaters I am considering should be a very easy install. Here are the two I am considering:
I used to think natural gas was the cheaper way to heat but nowadays I'm not so sure.
So what do you guys use? Which one would you choose?
I am leaning towards the natural gas one because I presently use my 220 outlet for my welder, but I do like the electric heater because it has a blower.
The heaters are on clearance right now at Northern Tool.
25,000 BTU natural gas heater $254
17,065 BTU electric heater $229
25,600 BTU electric heater $459
Are these good prices?? Anyone have a better source?
I currently use a portable propane heater that I hook to a 20LB tank. Yes it works but it does smell up the garage
a little and is somewhat of a pain to go and refill/exchange the tank.
