Classic Finn
sjptak wrote:Heikki,
I'm assuming those are hydraulic brake lines? They are required there? Is it because of the smaller tow vehicles the Yurps use? Sorry for all the questions.......
angib wrote:Errrr, Heikki, no!
Those are cables that operate the mechanical trailer brakes. You can see a single pull rod running from the mechanical surge coupler (1) back to a balancer on the cross-member where individual sheathed cables (just like car parking brake cables) (2) run to each wheel brake.
The parking brake just consists of a handbrake lever on the side of the coupler operating the trailer brakes the same way as the surge coupler does.
The surge coupler contains a gas damper so that the trailer brakes are applied and released progressively.
(1)
Oops, that one has the balancer built in.
(2)
Click on the pictures for bigger pictures.
Electrical trailer brakes are never used in Yurp and hydraulic trailer brakes are only used on commercial/working trailers. All leisure trailers (travel, boat, etc) have mechanical surge brakes.
Andrew
brian_bp wrote:That's a quite minimal frame, and there is a whole range available. I have noticed that the European manufacturers of recreational trailers (and commercial trailers) tend to use complete chassis from outside suppliers, rather than buying just axle assemblies and couplers, then doing their own frames, as is common here.
The two suppliers which I have found (Andrew et al can tell us if they are really the two biggies) are Al-Ko and BPW. Those web sites have lots of examples of their products, including chassis with complex frame rails and multiple cross-members. BPW has an amazing collection of PDF-format specs sheets on a products page.
