halfdome, Danny wrote:I found Mapp gas to work better than propane.Danny
madjack wrote:halfdome, Danny wrote:I found Mapp gas to work better than propane.Danny
MAPP burns hotter than propane so it should work quicker BUT I didn't have any so....... By the way Danny, didja use a Turbotorch for that MAPP gas or just a regular propane type????
..picture of propane torch I used from HF
easttexan99 wrote:Everything I read about annealing says that the smut is not a function of the annealing process, but rather, an indicator of when the process is complete. When the smut disappears, the metal is annealed, pending cool down. Supposedly you can do the same thing by rubbing a bar of soap on the metal and when the soap turns dark brown or black, the aluminum is annealed. Depending on the type of aluminum, annealing will occur between 650 and 750 degrees and should be allowed to cool slowly. Supposedly true annealing allows the metal to cool in an oven over an extended period.
