doug hodder wrote:I'd glue it down...ever see a car from the 70's with a big bubble in the vinyl top going down the road? the glue didn't hold and the wind high/low pressure differences is lifting it....seal the wood with epoxy first for water proofing, then apply the vinyl glue...doug
Chaotica wrote:Ok, I think I'm getting some crossed signals.
Does the vinyl need to be glued down or can it float? If it can float, a coat of epoxy on the ply would be the best in terms of watertightness since I wouldn't have to worry about adhering the vinyl.
asianflava wrote:I was checking out Jeff's trailer at LCG. I noticed (and asked him about it) that he put foam under the vinyl. I'd imagine that it would do a good job of hiding all the small imperfections on the wood.
