reduce, recycle, reuse: ideas for inexpensive trailer shells
Postby cwm » Mon Jan 08, 2007 11:40 pm
I love the idea of taking old discarded things and turning them into something useful again. Basically I come from a long line of rusty nail saving, do-it-your self rancher types, and I can't stand to throw anything away. So I'm trying to think of different already manufactured structures that could be repurposed as a travel trailer. This is mostly a creative exercise, I'm not sure that I will actually do this.
Here are a couple things that I thought of off the top of my head:
The abandoned shell of a VW beetle
A garden shed
A 600 gallon water tank
A section of light aircraft fuselage
Does anyone have any other ideas?
cwm
Postby sjptak » Tue Jan 09, 2007 5:26 am
Not that you'd be able to find an abundant supply in SoCal, but I've often looked at my next door neighbor's snowmobile trailer and thought about how easy it would be to make it into a camper. A friend of mine did make a camper out of oil tank, at least he started to. He died just before Christmas. He had a radical 32 Ford hotrod that he travelled in. Always talked about a motor home. He took a modle T truck body and was building his "oil truck". The tank was hinged so that he could use it to sleep in.
Stan
A tear drop wannabe but
a reasonably small TTT owner
sjptak
Images: 9
Postby dwgriff1 » Tue Jan 09, 2007 9:55 am
This thread suggests some wonderful ideas.
Don't have to worry about how it would work, or how to design the frame, shucks, just doodle.
Once built a whole series of model out houses. Maybe that is how I should revise that idea?
dave
dwgriff1
Postby cwm » Wed Jan 10, 2007 12:14 am
sjptak wrote:Not that you'd be able to find an abundant supply in SoCal, but I've often looked at my next door neighbor's snowmobile trailer and thought about how easy it would be to make it into a camper. A friend of mine did make a camper out of oil tank, at least he started to. He died just before Christmas. He had a radical 32 Ford hotrod that he travelled in. Always talked about a motor home. He took a modle T truck body and was building his "oil truck". The tank was hinged so that he could use it to sleep in.
Stan, I had the same idea about snow mobile trailers when I was in northern Michigan during the winter and saw a bunch of them. The oil truck sounds like a cool idea to
Charles
cwm
Re: reduce, recycle, reuse: ideas for inexpensive trailer sh
Postby Podunkfla » Wed Jan 10, 2007 12:43 am
cwm wrote:I love the idea of taking old discarded things and turning them into something useful again....
A garden shed
These Scandanavian folks made a pretty cool Sauna out of a Saab! :lol:
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby cwm » Wed Jan 10, 2007 1:10 am
A garden shed
Now that's what I'm talkin about! I'm inspired now. Good show.
cwm
Postby sjptak » Wed Jan 10, 2007 5:31 am
That is just way too cool. I mean HOT! You can even take it with you as its on a trailer.
Stan
sjptak
Images: 9
Postby dwgriff1 » Wed Jan 10, 2007 10:33 am
Good adapting of available resources!!!
In housing it's called "vernacular."
dave
dwgriff1
Postby cwm » Sun Jan 14, 2007 4:09 am
Ok everyone... I was at the wrecking yard today and I had a moment of inspiration. I give you, Hippie Airstream.
I wonder how much cantelevered weight you would need to have off the back to make it towable. I figure that if you put batteries, water etc. in back it could work.
http://tnttt.com/album_ ... c_id=17065
cwm
Postby Gage » Sun Jan 14, 2007 5:09 am
Aw, just do a little body work and move the axle forward.
Image Image Image
Gage
Images: 28
Postby dwgriff1 » Sun Jan 14, 2007 8:22 am
I like it. Shucks, make molds and cast it in fiberglass, then you could play with axle placement,
Or, move the axle and do a bit of bodywork to move the wheel openng.
Bet it woulnd't be light, but it would be an eyecatcher.
dave
dwgriff1
Postby Arne » Sun Jan 14, 2007 8:41 am
Problem with most ideas is they are heavy, and not insulated. It's great to recycle, but the end result has to be light, towable, and liveable. The reason we build what we do is to achieve and end result that serves a very specific purpose.
www.freewebs.com/aero-1
Arne
Mr. Subject Line
Images: 96
Postby JunkMan » Sun Jan 14, 2007 8:55 am
Gage wrote:Aw, just do a little body work and move the axle forward.
A van would give you plenty of room, but considering that the van is a unibody and how a VW suspension is made, that would be a MAJOR modification. A Bug would be easier, since the body unbolts from the floor pan.
I've looked at a Bug body several times, and tried to figure out a way to make something out of one (or a couple) of those, but just can't come up with anything that would look good and be functional.
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby cwm » Sun Jan 14, 2007 12:27 pm
Basically what I'm trying to do here is play with different existing shapes to get my mind working. I'm very visual, so I need to actually see something to figure out how to best use the space. I have come to the conclusion that one could build something like the dimensions and design of a VW camer bus on a 5x10 trailer frame.
A 5x10 trailer with a pop top is a very liveable space.
cwm
Postby dwgriff1 » Sun Jan 14, 2007 2:19 pm
The joy of this kind of thinking is the totally impracitality of it all.
It is a design exercize, not a reality show. Red Green would make it work, for a hundred feet, but the rest of us just dream.
dave
dwgriff1
