My New Tear concept
My New Tear concept
Postby vairman » Thu Feb 01, 2007 3:20 pm
Here is the first drawing of my new tear's sidewall layout..
It will be built out of 1" sq. tubing .050 wall and the total weight of the bare side should only be >50 lbs when finnished.
The current Dimensions are 14' x 5'3" also note that I haven't framed in the windows yet... So tell me what you think..
Greg :):)
vairman
Images: 215
Postby Miriam C. » Thu Feb 01, 2007 4:00 pm
NIce. So how tall is this going to be. It will make a great home away from home. :thumbsup:
Oh, aluminum tubing?
Postby halfdome, Danny » Thu Feb 01, 2007 4:26 pm
Is the slot on the bottom for the chassis? :)Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby vairman » Thu Feb 01, 2007 5:22 pm
Miriam C. wrote:NIce. So how tall is this going to be. It will make a great home away from home. :thumbsup:
It will be steel tubing and the overall height will be 6'3" appox.
Greg 8)
vairman
Images: 215
halfdome, Danny wrote:Is the slot on the bottom for the chassis? :)Danny
Yep! that's what its for...
Greg 8)
vairman
Images: 215
Postby Gaston » Fri Feb 09, 2007 2:23 pm
1"steel tube by .049 weights .59lbs per foot so it looks like your going to have at least 65 lbs and if the mid frame and door opening frames are larger it will be a few lbs more. Then you still have the weight of the inner and outer wall covering and insulation .....but it should be plenty strong. you could save a few lbs by losing the lower side rail and even more if you make the side rail of the trailer part of the cabin and lose both side rails :thinking: I made my hatch frame from 1" tube and found you have to watch your" heat warp" close or the end result gets real interesting
The difficult we do now... the impossible takes a little longer
Gaston
Images: 98
Return to Member Designs
