by Leon » Mon Feb 05, 2007 3:46 pm
I figured about where the spring would have to attach due to available stroke, then I opened the hatch and put a stick from that point to a scale on the floor of the teardrop. That weight was the weight of the hatch at that point. A longer stroke spring will allow you to move the mounting away from the hinge, therefore because of leverage, it will weigh less at that point. I then divided by 2 (used 2 springs) and bought the next heavier spring. If I figured 30 pounds, and they are available in 20 and 40, I got the 40s.
