Interesting framing method...
Postby 48Rob » Mon Feb 05, 2007 2:01 pm
Interesting framing method used back in the thirties.
It appears that the company sold fastener kits, you supplied the wood.
Looks pretty do-able, even today...wonder if anyone has a set that could be copied, or reproduced?
<img src="http://i10.ebayimg.com/02/i/000/89/3a/e697_12.JPG"><P>
E bay link
Rob
48Rob
Postby Ira » Mon Feb 05, 2007 2:53 pm
What about those curved roof pieces. That's lumber, right?
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby JunkMan » Mon Feb 05, 2007 2:56 pm
The Hammer Blow Company is still around, they make "BullDog" couplers for trailers. Very heavy duty, great for larger trailers. I have one on my car trailer, and love it. I have trashed several of the regular stamped steel couplers, but the BullDog is cast.
Jeff & Odie
Black Hills of South Dakota
JunkMan
Images: 50
Postby prohandyman » Mon Feb 05, 2007 5:27 pm
Oh my god. I just saw a box of "Hammerblow" wood connectors of some sort at my inlaws barn. I am going tonight to see if he has tossed them yet! They were with other items destined for the landfill!?!! I never even gave them a second look, only to notice the name. I will put the coveralls on (its -4 degrees) on go there now :worship:
Dan
prohandyman
Images: 785
Postby 48Rob » Mon Feb 05, 2007 6:01 pm
Wouldn't that be cool if they really were... :applause: :applause: :worship:
48Rob
Postby halfdome, Danny » Mon Feb 05, 2007 6:18 pm
halfdome, Danny
*Happy Camper
Images: 252
Postby tonyj » Tue Feb 06, 2007 11:48 am
What an interesting axle spring placement! I guess they hadn't heard about "wide track."
tony
tonyj
Images: 160
Postby Nitetimes » Tue Feb 06, 2007 11:51 am
tonyj wrote:What an interesting axle spring placement! I guess they hadn't heard about "wide track."
How'd you like to change that tire along side the interstate??? :cry: :cry:
Rich
- Thomas Jefferson -
Nitetimes
7000 Club
7000 Club
Images: 194
Postby brian_bp » Fri Feb 09, 2007 7:09 pm
Similar connectors are still sold in building supply stores, normally for making sheds - they're often sized for 2x4 lumber. I wasn't aware that the method was ever used for trailers - interesting find!
I didn't even notice the outboard spring until tonyj's post. It makes sense structurally, if there is no internal frame, and people sometimes still do something similar when building with bicycle wheels and axles, but that's another travel trailer first for me.
brian_bp
Images: 9
Postby Ira » Sat Feb 10, 2007 3:23 pm
brian_bp wrote:Similar connectors are still sold in building supply stores, normally for making sheds - they're often sized for 2x4 lumber.
Northern Tool makes a kit for 2 by 2 lumber--and you're right:
It's for a shed or greenhouse. Depending on the size you want to build, you just order an additional kit. The kit is nothing more than a bunch of small joist hangers at the correct angles to build a rectangular, perpendicular shed with pitched roof--including the angle you need for the roof joists. (The ONLY reason to buy the thing.)
I built one like 12 years on my property near Big Cypress, but I never skinned the sides. I just wanted something to cover my well pump. It really stunk six ways to Sunday, and I don''t think it's the "best" way to build anything.
You still have to square things up correcly, level everyting, cut your lumber correctly, etc. So all of these hangers are kind of superfluous at this point. Aside from the roof joist connectors with that certain angle, you can get the rest of the connectors at any box store.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby 48Rob » Sun Feb 11, 2007 12:53 pm
Here is a more detailed view of some of the brackets...they look a bit more substantial that the flimsy ones I've seen lately...
<img src="http://img.photobucket.com/albums/v284/1948rob/awning/resized11.jpg?t=1171215940">
48Rob
Postby Big Dave » Mon Feb 12, 2007 3:01 pm
Yeah, and they were built using better wood and probably never broke 35mph either. It's cool to look at and if you were building a museum piece I could see it, other than that it looks like a whole lotta work (and weight) to reinvent the wheel. I like looking at the old designs for style cues and storage ideas, but then I'm always thinking about using them with modern construction methods.
You know, you could always skip the brackets and just use pocket screws.
Big Dave
Postby bdosborn » Tue Feb 13, 2007 11:46 pm
I used sheet metal brackets on my framing:
Adds a ton of strength for very little weight.
Images: 806
