Glue and screw I will, by 100% agreement
, followed by extensive sealing. My thought for sealing was to silicone all edges of the frame, then to use a very good oil based primer (2 coats) and a very good oil based polypaint, like they use on porches and patios (2-3 coats). The entire TD will be done this way as it's to be covered in aluminum anyway. The only chance of water being held in will be by the underfloor insulation. I'm going to use 1.5" rigid pink, however, it will be exposed with the hopes that any water that does get up in there between the insulation and floor can get out and also get air to dry. That's the thought anyway.. MAN AM I EXCITED... if I put the floor down and prime tonight I can paint tomorrow and stand walls on Saturday and enjoy Barley Pop on Sunday.
