Now I just have to figure out how to hook up the drain
Once I get the courage to actually cut a hole in my pretty counter, I will post pics.
Mk
Classic Finn wrote:PS - MK it was only about a month ago that the wife suggested a stainless bowl here also to use as a sink but I admit... I laughed at the idea.. boy do I regret it now...when I see yours...![]()
See guys - got to listen to the women once in awhile...![]()
Mary K wrote:Thanks Yall!
After getting home, and trying to install the drain, I found that a flat bottom bowl doesn't conform to it very well.![]()
I think I need a thin rubber washer for the inside of the bowl instead of using plummers putty.
Ahhhh well, if it was easy, everyone would be doing it.....I'll keep ya updated with what works.
Mk
lcurrie wrote:You could always make the hole smaller than the sink and install it above the counter...
http://www.us.kohler.com/ideas/showcase/showcase.jsp?section=3&nsection=3&nsubsection=1&subsection=1&aid=669
Miriam C. wrote:Mary K can you use a washer intended for sinks on the bottom instead of top? Keep using your putty too.
Ira wrote:Mary, the putty should work fine, as long as it's flush enough for you and not sticking up a mile.
AND MAKE THAT HOLE SMALL AND USE THE SANDER TO FULLY OPEN IT TO SIZE!
