Ugh Major mistake on second wall
Postby Keith B » Wed Feb 14, 2007 12:16 pm
Hey Danny... that Gorilla glue is crazy strong.... I laminated some wood together to make a teet-r-totter - well, I didn't understand it fully and I laid the wood on the floor to dry... YUP, you guessed it, the glue expanded and contacted the concrete..needless to say, I had chipped concrete by the end of the day. :lol: I've heard that since it uses moisture and air to cure it can actually dry wood out where it is contacted and potentially split at the ends.. have you experienced this? I guess my fright just made me stick with what I knew, which was Titebond - I need to play w/ Gorilla type stuff some more, seems to be pretty popular. OH and FYI: you're not missing Kansas today, we already reached our high of 5 degrees - it's criminal cold here. :(
Keith
"Work and work and do your best! Paint and putty will do the rest!"
Keith B
Postby madjack » Wed Feb 14, 2007 12:23 pm
Keith, we have used Gorillla Glue extensively and if used as directed, it is an excellent product...a note...while GG expands and will fill up a gap, the mechanical bond in that gap is not as strong as if you had used a construction adhesive which has a much better gap filling capability...
madjack 8)
Postby Keith B » Wed Feb 14, 2007 12:29 pm
Good to know - such great tips and advise on this site. The glues they have now a-days are amazing - my only problem with Gorilla glue was PURELY my own stupidity for not following and/or understanding it fully - I wasn't the best in science in my learning, but I'm sure glad someone's using it to make these awesome products - sure makes life easier for all of us.
Keith
Keith B
Postby Et Cetera » Wed Feb 14, 2007 12:31 pm
Don't think of it as a mistake. Think of it as one wall closer to a good start on a second teardrop.
8)
~Teri
Et Cetera
Images: 28
Postby Keith B » Wed Feb 14, 2007 12:33 pm
:lol: :lol: :lol: :lol:
EXCELLENT THEORY!!! :applause:
Keith
Keith B
Postby madjack » Wed Feb 14, 2007 12:33 pm
...a tip for cleaning up the glue line when using GG...GG foams and will leave a hard to clean "foam" line when it sets up...to avoid this, about 15minutes after clamping, the foam should start showing up in a big way...keep a rag soaked with solvent and wipe the foam off before it sets...much easier than trying to scrape/sand it off latter.............
madjack 8)
Postby halfdome, Danny » Wed Feb 14, 2007 2:02 pm
Keith the main reason I keep Gorilla Glue around the shop is for exotic woods. I turned this segmented bowl out of Machiche & figured Maple to about 3/32" thick on the walls and after 4 years it's slightly deformed from wood movement but every glue joint is as tight as the day I turned it. Notice it’s real thin at the second lamination from the maple that light shows through. This bowl is kept in an unheated room and the Gorilla Glue has performed very well. :D Danny
halfdome, Danny
*Happy Camper
Images: 252
Postby Keith B » Wed Feb 14, 2007 2:16 pm
Well, it looks like I just need to get over the "fear" of my bad experience and give this stuff a whirl - especially knowing what it will do and the tips from you and madjack - and VERY AWESOME :thumbsup:
Keith
Keith B
Postby Lynn Coleman » Wed Feb 14, 2007 8:40 pm
Et Cetera wrote:Don't think of it as a mistake. Think of it as one wall closer to a good start on a second teardrop.
8)
:D
Lynn
Lynn Coleman
Images: 115
Postby Lynn Coleman » Wed Feb 14, 2007 8:46 pm
halfdome, Danny wrote:Lynn, The reason for suggesting Gorilla glue is it's gap filling capabilities. I usually use any of the Titebond glues depending on what I'm dealing with. :) Danny
Thanks for the information Danny, I appreciate it.
madjack wrote:Lynn, regardless of what kinda glue or patch you end up using, a spline, bisquits or pocket hole screws should be used as well
madjack 8)
Thanks madjack. What are pocket hole screws, these are new to me.
Lynn
Lynn Coleman
Images: 115
Postby Miriam C. » Wed Feb 14, 2007 8:54 pm
Lynn,
This might give you a good idea.
http://www.rd.com/content/openContent.d ... ntId=17686
Enjoy
Postby dhazard » Wed Feb 14, 2007 10:15 pm
Before using Gorilla Glue check out this warning. http://tnttt.com/viewto ... ght=danger
Many miles and many tears. Times were hard but now they're changing.
You should know that I'm not afraid.
dhazard
Images: 122
Repair Update
Postby Lynn Coleman » Tue Feb 20, 2007 11:33 pm
Hi all,
Well we used the spine idea (Thanks Danny), gorilla glue for the width of the blade cut (thanks all) and Titebond III for the rest of the glueing. I've heard it said that we over build on our first trailer, we'll that may be but I'm still concerned with the idea of it falling apart the first time we take it down the highway, so, we'll overbuild, I hope. 8)
The repair is done now we have to polish it up and finish it off. Below is a pic of a corner of the repair. It is the bottom wall and the other wall is sitting on top of it in this pic. Image
I'm sorry I forgot to take a picture of the actual repair but we need extra sets of hands to move these walls and I didn't think to get the camera first.
Thanks for all the help,
Paul & Lynn
Lynn Coleman
Images: 115
