Thank you for your input in advance??
Mk
Mary K wrote:Thank you for the info guys!!!
Filter??? But that would ruin the hose water taste. And I have such fond memories of drinking hose water as a kid after a day of hard play outside![]()
Mk
brian_bp wrote:It's quite normal for campsite water to be connected directly to the plumbing which feeds the faucet in a travel trailer. My Boler is done that way, and I also have a tank and pump for when there is no campsite water. Because of the pump, there's a check (one-way) valve at the inlet so my pump doesn't send my water out the "inlet", but if you have no tank/pump onboard you don't need that.
While there is no obvious reason for campsite pressure to be higher than in a house, I have heard it often is. Apparently, in order to have enough pressure at the most remote sites, some campgrounds pump it to a high pressure, so if you are close to the source it can be too high. I have a regulator (yes, they're cheap, get 'em at WalMart), and one tip is to put it at the tap, before your hose, not at the trailer end... keeps your hose from getting blown up.
