Thanks John
halfdome, Danny wrote:I have their pistol grip shearer and like said before WD40 makes the thing work. I found the air hose at the base of the handle hit the aluminum and I couldn't make full contact with the aluminum to make it cut continuously. I installed a brass elbow to direct the air hose up and away. In retrospect I would get the one without the handle.Danny
Lone Wolf wrote:halfdome, Danny wrote:I have their pistol grip shearer and like said before WD40 makes the thing work. I found the air hose at the base of the handle hit the aluminum and I couldn't make full contact with the aluminum to make it cut continuously. I installed a brass elbow to direct the air hose up and away. In retrospect I would get the one without the handle.Danny
Danny you can loosen the 2 bottom allen screws on head and rotate it to any position.
