Another stupid question
Postby pauld3 » Thu Mar 01, 2007 12:19 pm
When your using a torsion axle, how do you determine the starting angle.
Thanks Paul
Paul & Lynn Donovan
The Toad Drop Inn
Liberal, KS
pauld3
Images: 94
Postby Juneaudave » Thu Mar 01, 2007 1:10 pm
You need to know how high you want the frame from the ground, and use a table that shows the dimensions of the particular axle. For instance, here is the link to Dextor Torflex Torflex Literature
Juneaudave
Images: 380
Re: Another stupid question
Postby asianflava » Thu Mar 01, 2007 2:23 pm
pauld3 wrote:When your using a torsion axle, how do you determine the starting angle.
Thanks Paul
I kinda guessed. I figured that 45 would be too tall and 0 would be too short. I split the difference and got a 22.5. It's a little taller than I'd like (visually) but it worked out just fine for me (I've never scraped the rear end). Of course, your mileage may vary.
asianflava
Postby madjack » Thu Mar 01, 2007 7:34 pm
...start with Steve's reply here;
http://tnttt.com/viewto ... 725#183725
...for us, we used a 205-70-15 tire...this tire is slightly over 26" in diameter...a 0* start angle gives us about 12" clearance to the bottom of the axle tube...just what we were loking for...
madjack 8)
