Dooner Is this the trailer you are talking about? wrote:This is for anyone that has used theTS 4X8 no floor trailer.
angib wrote: A pair of 2"x1"x1/8" rectangular tubes (with the 2" vertical) angling off the tongue fairly near to the hitch and running out to the side rails at least 12" behind the front of the frame would roughly double the strength.
angib wrote:Jeff's (junkman) first photo shows exactly what I meant. In your case the braces would land on the side of the tongue, not underneath like Jeff's.
When you say the tongue doesn't permanently dip down, that sounds like something has broken, not just bent - if the tongue can move, something must be damaged quite a lot - like a broken weld. You need to lie underneath it while somebody pumps up and down on the tongue to locate the problem.
Having the front of the trailer propped while you're lying underneath would, of course, be a good idea!
Andrew
Dooner wrote:Sdtripper2,
That is the trailer I have, but my GVWR shows to be rated at 1500 lbs.
Where did you get the 2000 lbs rating?
