I've been buying cloth from
http://www.raka.com/. On my stripper woody, I'm using a 60" wide 4 oz cloth. 60" is good for a 5' wide build because you don't have to overlap pieces to get the width.
On my stripper canoes/boats...I typically use a 6 oz cloth...once you get up to 9 oz or so, it gets much more difficult to wet out with epoxy.
One thing that you can do is rather than buy tape, you can cut the cloth on a bias to make your own strips. The bias cut will conform to the curves and angles much better. Regardless, on the outside, I don't know if you can get the cloth to wrap around the corners without it puckering up. You may have to use tape on the outside joints, then fair it in for the cloth.
Smoothness should not be a problem within reason. I find the main difference in a 4 oz to a 6 oz, is the amount of epoxy it takes to fill the weave and the lighter the fabric, the more care you need to take in handling it.
On your build, if you decide to use cloth (and I'm not certain that is the way to go), you will have some problems glassing where the curvature turns towards the underside. It's much more difficult to do on an underside without making a big mess.
You might give Larry at Raka a call and have hime take a look at your pictures. Larry is pretty helpful and may have some ideas.
Good luck...
