Chrome Logo
Chrome Logo
Postby dmb90260 » Tue Mar 06, 2007 7:33 pm
I was lucky to find the Kenskill logo that had been on my trailer and pick it up off e-bay. It had been painted over so I cleaned it as much as possible and took it to a shop for an estimate to re-chrome it.
Sadly even if it could be cleaned up more, there is too much corrosion and it will cost a minimum $120 for an okay job.:o
Does anyone know of a way to have these re-made using the original as a template?
Dennis
Join the Kenskill Karavan at:
http://autos.groups.yahoo.com/group/kenskill_karavan/
Real Men cook with Black Iron
The Buzz In the Dale: The Buzz In The Dale
dmb90260
Titanium Donating Member
Images: 134
Postby toypusher » Tue Mar 06, 2007 7:39 pm
You could try to find a place that does custom castings. They should be able to reproduce it for you. I know some of them use sand to make a mold and then pour metal into the sand mold. You could then have that chromed, but I'm afraid that it will cost just as much!
toypusher
Images: 324
Postby Gage » Tue Mar 06, 2007 7:43 pm
Dennis, you might try and make a clay mold and poor some lead and go from there. I have no idea of what I'm talking about. It just sounds good.
Image Image Image
Gage
Images: 28
Postby Micro469 » Tue Mar 06, 2007 8:02 pm
PM Cheroke George. He may be able to help......
John
Micro469
Images: 382
Postby Dean in Eureka, CA » Tue Mar 06, 2007 8:15 pm
Dennis,
You might wanna talk to George... He does casting.
I know a little bit, but not much...
They make a wooden frame and fill it with green sand... I think it's called bentonite. The sand is really fine, almost like dust... It's tamped down a bit then a positive model is pressed into the sand bed and removed... leaving a negative mold into which the casting metal is poured.
Like I say, I don't know much, but I'm thinking that something like the KenSkill script would be better reproduced using the lost wax method, with a centrifuge... A carved and shaped hard wax positive is made and placed in plaster, fired in a kiln to make the wax "lost". (The wax would also have "inlets" added, which are cut off and discarded once the piece is cast) The plaster negative is then placed into a centrifuge, metal is poured and the centifuge spun, assuring the mold is completly filled.
Dean in Eureka, CA
The Fogcrawler
Images: 69
Postby Chuck Craven » Tue Mar 06, 2007 8:28 pm
Take it to a CNC machine shop and have it milled out of stainless steal.
Stainless steal will polish up like chrome. It will cost a lot to have it done. Or have it cast in brass, then have it chromed. That is probably the cheapest.
Chuck
Chuck a new td builder
Chuck Craven
Images: 62
Postby s4son » Tue Mar 06, 2007 8:49 pm
Could you have it cast in aluminum and then polished. No chrome.
Scott F. :thinking:
Are we there yet?
s4son
Images: 180
Postby kerryd » Tue Mar 06, 2007 9:16 pm
Dennis , we have a cnc plasma . It would cost you about $20 to cut out . Plus shipping . About $7 . We can cut it out of Aluminum or stainless . Kerry
kerryd
Postby Micro469 » Tue Mar 06, 2007 10:05 pm
kerryd wrote:Dennis , we have a cnc plasma . It would cost you about $20 to cut out . Plus shipping . About $7 . We can cut it out of Aluminum or stainless . Kerry
Keryd...Could you make a couple that spell Slumbercoach.. in the scrpt used by Pontiac back in the sixties? IE Pntiac, Bel-Aire....
John
Micro469
Images: 382
Postby kerryd » Tue Mar 06, 2007 10:13 pm
John , If you can tell me where to find or direct me to pictures of the lettering ,I'm sure we can . We also can have them powder coated too. Keery
kerryd
Postby Micro469 » Tue Mar 06, 2007 10:20 pm
I'll look for them and let you know. I got a picture in my head...... but my print button doesn't work... :lol:
John
Micro469
Images: 382
Postby Podunkfla » Tue Mar 06, 2007 11:22 pm
The best chromer I know by far is Mike Chiaurro who owns: http://gatewayxtreme.com/ He stays busy just doing Honda VTX owners chrome... He also rides a VTX (like me).
He is prolly at Bikeweek right now (usually at the Rat's Hole bikeshow area)... He is very good and not all that expensive... And, trust me Bike nuts are picky about quality. I have... and have seen a lot of his work. :thumbsup:
You can contact him at: [email protected]
some chrome: http://gatewayxtreme.com/chromedproducts.htm
some prices: http://gatewayxtreme.com/chromepolishingexchange.htm
<B>~ Brick
Image...Lots more pix here!
Podunkfla
ol' noodle haid
Images: 5
Postby dmb90260 » Tue Mar 06, 2007 11:34 pm
I will PM you. Thanks
Dennis
dmb90260
Images: 134
Postby angib » Wed Mar 07, 2007 5:09 pm
Dennis, the CNC-cut from stainless sounds like a really good solution - and you get to spend many happy hours polishing the cut edge to perfection. Don't forget the easy way to make the CNC model - put your existing nameplate on a scanner and then draw over the scan. If you want help with that, PM me.
Andrew
angib
5000 Club
5000 Club
Images: 231
Postby dmb90260 » Wed Mar 07, 2007 10:44 pm
angib wrote:Dennis, the CNC-cut from stainless sounds like a really good solution - and you get to spend many happy hours polishing the cut edge to perfection. Don't forget the easy way to make the CNC model - put your existing nameplate on a scanner and then draw over the scan. If you want help with that, PM me.
Thanks Andrew; I am seriously out of my depth with this. The piece is on its way to Kerry right now. He will have to figure out how to do it. I am clueless. :cry:
But it is nice to have friend who do know what they are doing.
Dennis
dmb90260
Images: 134
Users browsing this forum: Google [Bot] and 0 guests
