Need help finding interior corner edge stripping
Postby DaveraG » Sat Mar 10, 2007 7:36 pm
Hi folks!
Well, the hubster and I are making slow progess, but at least making progress on our Cubby. We hunted all over Home Depot last weekend for something to use for the interior corner edges and came up empty. Everything for corner edging went over the OUTSIDE edge, not the finished edge being in the interior angle (make sense?) What have you folks done?
Maybe we are just not calling it the right thing. We envisioned it being metal (but any ideas for alternative material would do...) Any ideas for the amatuers?
Many thanks in advance for your help!
Davera ( & Adrian)
DaveraG
Postby Micro469 » Sat Mar 10, 2007 7:52 pm
Wooden cove moulding comes to mind..... or 1/4 round moulding. If you get it small enough it should bend quite easily with very little persuasion... ;)
John
Micro469
Images: 382
Postby Phil & Ningning » Sat Mar 10, 2007 9:58 pm
I made some cove molding with a table saw and router table from pine. It bends fairly easily, but the sharpest part of the cubby profile required me to soak it in water first. It's about 3/8 x 3/8 inch. Some glue and headless nails hold it in.
Phil & Ningning
Images: 65
Postby Laredo » Sat Mar 10, 2007 11:11 pm
Or you can get the piece they cut the quarter round out of -- I have no idea what it's called but at Lowe's and some Ace Hardware you can get it in up to 12' pieces and it's very bendy, almost like ribbon cable.
Laredo
Postby Tim & Lori » Sun Mar 11, 2007 7:37 am
http://tnttt.com/album_ ... c_id=17079[img]
I wanted something like quarter round but all I could find at the local Lowes & Home Depot was 1/2" quarter round that looked out of proportion to the rest of the interior and was hard to bend to the interior radiuses. What I found was screen molding that was 5/8" wide and 1/4" thick. I cut it in half (carefully) down the center and wound up with 2 strips of 1/4" quarter round with a nice radius and easily bent. Put it up with glue & small brads, some wood filler and it looks great. Just a thought.[/img]
won't be long now....
Tim & Lori
Images: 134
Postby Ira » Sun Mar 11, 2007 7:54 am
This might not go with your theme at all, but I and a few others used rope--in my case, nautical manilla rope.
And HD has nylon rope in all colors.
Here we go again!
Ira
Forum Storyteller
Images: 118
Postby len19070 » Sun Mar 11, 2007 8:48 am
Davera
Knowing what "They" call it is important. Usualy what they call it is so far off from what a comon sense name would be that its easy to get missed.
Heres what I used.
Hollow Bead Welt??
(theres a good name for "Inside Corner")
Not the cheapest place to buy it but here it is.
http://www.rvsurplussalvage.com/catalog ... ct_id=2718
http://cgi.ebay.com/ebaymotors/RV-Marin ... enameZWDVW
Happy Trails
Len
len19070
Images: 24
Postby Dooner » Sun Mar 11, 2007 11:21 am
Dooner.
TED NUGENT FOR PRESIDENT!
Dooner
Images: 69
Postby Todah Tear » Sun Mar 11, 2007 10:20 pm
If you want to use the "rope effect", go to a fabric store. They have braided cotton rope for about 50 cent a yard (They have various sizes, so cost may be + or - 20 cent.)
I used it to trim around the base of my front windows' framing. Glued it into place. I saturated the rope w/acrylic paint ($5/gallon in the excess paint section of Lowes). Lastly, I put a final coat of paint that matched my other trim.
Todah
Todah Tear
Images: 282
Postby Laredo » Sun Mar 11, 2007 10:34 pm
That's kinda not what I was thinking of ... in the drawing below it would be M2. But M24 is nice too.
Laredo
Postby DaveraG » Sun Mar 11, 2007 11:38 pm
These are all really great ideas. Thanks so much! This forum is an awesome resource...
I am really liking the idea of using rope. We stained the interior wood, but are now considering painting it anyway, as the stain didn't go on so well. We have epoxy on the wood in places we couldn't see before staining, and the stain didn't take in those places. So we are reconsidering the approach there..
Thanks again all: I'm sure you'll be hearing from us again!
D.
DaveraG
Postby Ira » Mon Mar 12, 2007 5:05 am
The rope is very rigid. In other words, it doesn't "flop around" all that much, and a few finishing nails here and there sets it in place.
Granted, I used manilla, which I think is a lot more rigid than the nylon, but you can see for yourself at the store if you think the nyon rope or fabric yarn will work for you.
Here we go again!
Ira
Forum Storyteller
Images: 118
